First I would like to welcome myself here... Just signed up. Bought my first house in September so I will be fairly regular on here, etc. Never in any form of construction outside of helping people here n there and making/fixing things, etc. So I will thank everyone that responds first hand because any help is appreciated.
Anyway... My main drain backed up a couple times already from tree roots, typicaly older house(had it snaked, no real concern at the moment, will have to remove tree eventually) however I noticed that after the water dried up the last time I still had a little bit of a puddle by the wall right under where the main water line comes into the house. So I tracked it and its on my side of the shut off valve coming from the threading. It has some goop on it, like a build up so I assume it just was never doped or Teflon prior to them tightening it(whole house was redone in pex).
So here's my question, because it seems to obviously be fairly easy job... Cut the water off at the valve, back it out, put on tape or dope and re thread. But with the elbow flange for the main line and the pex line... I'd have to remove both sides correct? That way, twist the elbow back onto the main line and "re-crimp" the pex line... Would need the tool correct? Also last question is can I drain all the water out of the system by just turning it on in the sink, etc? Thanks again for any answers. Here are some pics.
It leaks on the bottom side of the elbow from the threading...
