Howdy-hey forum-folks,
After 12 years of living with no garage or falling-apart garage, I am finally in a position to be able to build a new one. Hooray!
I am a fleet mechanic for the city I live in, mainly police and fire vehicles. I do a fair amount of side-work at home, thus a nice garage is important to me. Mostly I do the real PITA electrical/electronic diagnosis and repair that dealerships seem to hate...or charge huge amounts for. The odd remote starter, the occasional contract job for the local PD on 'discreet use' vehicles, and so on.
The footprint I have to work with is 36x26. That would leave one 10' parking spot along one side and 6' to the property line on the other. The current garage is a 24x22 with a 12' addition on one side that is...umm...rotting off, basically. There is no saving this garage, the slab is cracked into 9 pieces and they're all moving in different directions on soggy ground.
We get down to -25f in the winter here, and I get some wicked wind off of Lake Superior 6 blocks away. I have hot water heat in the house, and will likely have 4-6" of foam board under and around the slab, with several 200 ft 1/2" HEPex in the slab for heating. I haven't done an accurate heat loss to decide the particulars yet, too many variables left to clean up.
But the rough plan is to maintain 50* with the in-floor, and have a gas or electric ceiling-mount shop heater to bring the temp up to 60-65 while working. The garage will be its own zone, with antifreeze, heated from the house boiler thru a heat exchanger. I intend to bury a 3 or 4" run of PVC from house basement to garage to carry electrical, phone line, audio/video, and the heating supply and return.
The service drop will be upgraded to 200amp and drop to the garage, to a 200a panel, then run to the house as a 100a subpanel, basically.
I hope to have at least a section of the garage with a 12 ft ceiling so I can installed a standard 9000 lb 2-post hoist. I could probably get by with 10'6" if I had to.
What I'm really wondering, before I lay down exact plans and get the process going, is...
For those of you that have built yourself a garage/shop, or remodeled your garage/shop, what would you do differently, what do you regret, and so on? I don't want to go through this and think "Aw, crap, that's what I should've done."
Thanks!
Thanks!
