Hello All,
I am installing a 40 gallon electric tank. The problem is that this new tank is an inch taller than the old tank. The relief valve is actually higher than the copper coming out of the wall where it will connect. I was going to use the flexible, braided stainless steel hose and make a loop for that. The cold water inlet and the hot water outlet are also tight. I have enough room for a 3/4" elbow and about 1/2" of straight pipe and then the 3/4" female which will thread onto the male fitting of the tank.
My questions:
Is the flexible stainless acceptable for the pressure relief ?
Is it alright to have an almost immediate 90 degree into and out of the tank?
Lastly, The #4 copper ground line is attached to the cold water pipe, but is between the shut-off and the tank, not between the shut-off and the ground rod. Will this be alright?
I hope this makes sense.
Thanks In Advance,
Russell
My questions:
Thanks In Advance,
Russell
