Hello everyone - I'm in the process of planning a new 12 x 32 foot in the corner of our "L-shaped" ranch style home.
The land that I'm building the deck over is recessed by about 18 inches and the door that I want the deck built level too is about 23 inches from the ground. Due to the fact that the ground is recessed and the deck will essentially be level to the ground, one step down, how much do I need to worry about cross ventilation? There won't be much due to the layout of our property as I mentioned as the joists will essentially be level with the ground. I am using pre-treated lumber so I know it's not as much of a concern as if I was using composite, I was thinking that I could leave some of the corners open and lattice it 'closed', but I also have 3 children under 5 that I would worry about.
Also - for anyone in MA, I'm reading through the code book and don't see a lot of information on the floating foundation system that I'm planning on using. A lot of the documentation discussess anchoring the deck to the primary structure, but I'm not planning on doing that. It does say that if, during inspection the structure can't be verified that it needs to be self-supportive, but that is about it.
Also - does the code require that the ground be clean under a deck? I see it is required if the lumber is directly on the ground (which I'm not doing), so I just wanted to confirm. I don't want any surprises during the inspection!
Thanks in advance for all your help!
Keith
Keith
