I've decided to do a new build in a new small sub here in Florida however I'm no more experienced in construction than the average guy on the street. I'm building with one of the big three home builders and I'm considering hiring a professional home inspector to check things out a few times during and after construction.
Basically I want to ensure it isn't 4pm on a Saturday and one of the guys working for the sub contractor decides he's close enough to done with applying sealant to the stucco and I won't notice if he "forgets" to finish the back end of the house and takes off. The first major storm we have and I have a swimming pool in my bedroom and that expensive laminate I put down is now ruined.
Unfortunately I've heard a few times of people in and around the area having issues with their homes after purchase only to be met with minimal repose from the builder. Yes one of them was water intrusion inside their CBS home. Another was stucco that cracked extensively all over the structure which was patched with caulk then painted which eventually cracked again.
I want to ensure all is good with the construction and I've a good solid home when they are done. It isn't that I don't trust the builder or even the sub contractor. I don't trust people to not cut corners or skip things.
Thoughts, suggestions would be most welcome.
