1 - 13 of 13 Posts
I have a 1.5 year old, 2 story home in Iowa. There have been some pretty large cracks on certain second floor walls, and a lot of doors not latching. Today I noticed the large basement egress windows do not have a typical header, and it looks as if the plates are sagging in the center of the windows. The "header" that is above the window is basically two 2x6s, on the flat, supported by one jack stud on either side. One of the plates above this "header" has a break without any support, other than the "header", below it. I am pretty sure that, on the flat, 2x lumber is not capable of supporting a 5' span of weight bearing wall, such as my windows. There were several issues that the building inspector caught prior to passing, maybe this was overlooked? Can anybody verify this? Thanks.
Concrete & Masonry
Pull the insulation back first & check to see if the floor joists are hangered to the skirt. Or possibly the skirt is even doubled up for the actual header.
Discussion Starter #8
Bsmt Window
I took a measurement on the inside, from the rim joist to the edge of the 2x6 plate. It came out to be 2-1/2" so it must be doubled. I feel a little better now, thanks jomama45.
Registered User
It looks like a good insulation job to me......caulked and sealed between all layers.
If the rim is doubled and I-joist hung, it should be no issue, as noted from jomama45
Agreed, provided the rim board used is able to serve as a header. An i-joist floor system does not use dimensional lumber rims, so an OSB rim was probably used. Many/most are not rated as headers. LVL's are typically used at these locations.
USA1Corey, can you post a picture of the rim joist that the i-joists are hangered to? If it has a veneer face, you're good. If it looks like OSB there might be an issue, depending on the brand.
uva uvam vivendo variafit
Carpenter
How is that vinyl window or door in the picutre operating?
If the wood above it starts to sag from weight above, it will bend that vinyl frame easily. If that window is functioning properly, then issue may not be in that area.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
1 - 13 of 13 Posts
