1 - 14 of 14 Posts
AMANA ASZ140241AD 2-ton Split System Heat Pump
Replacing the original Condenser Fan Motor with a universal fit Dayton 4M205 from Graingers.
Am posting my Original Configuration schematic and my Proposed Configuration with the new motor for your consideration before I energize the unit. The new motor is not a plug-n-play since unfortunately the wire colors are different. Also, it would be a lot easier if I had the inside schematic of the new motor like the old one has.
Thanks in advance for any comments.
No, that wiring isn’t correct. Looks like your feeding from the same leg. And your replacing a duel speed motor with a single. Why?
Discussion Starter #3 (Edited)
The last repairman installed a single speed 4-wire motor that ran for just 1 month out of the 1 year warranty. The only Goodman-Amana 2-speed motor I can find has just 3 wires (Blk - Brn - Blu)
Super Moderator
The white wire needs to connect to T2 of the relay.
Discussion Starter #5
Thanks for the reply "beenthere" . . . I submit version2 . . . apparently my original fan motor is obsolete
Super Moderator
It will work like that, but its a bit unconventional. It would be better to have the white on the relay/contactor itself. Less confusion down the road, if you ever have to have somebody else work on it. Or sell the house.
Discussion Starter #7 (Edited)
Thank you . . . perhaps you can tell me the difference between a Start Cap and a Run Cap . . . since if I go with this new wiring, half of the Dual Cap isn't being used?
Super Moderator
If your referring to the run cap in the diagram. Always best to use a new capacitor when installing a new motor.
Super Moderator
Thats better.
Discussion Starter #11 (Edited)
Thats better.
Now the bad news . . . the new condenser fan motor is up and running and now the evaporator fan motor tries to start but only oscillates briefly. Compressor & fan motor come on but then turn off in a minute after they sense no heating-cooling transfer on the inside coil. As a result the suction line gets too hot to touch before this shutdown. Hope the compressor isn't damaged.
BTW, it's a scroll compressor.
Super Moderator
Check the capacitor of the indoor motor.
Discussion Starter #13
It's a 3/4HP 220V 5A ECM so I'll have to see if it has one? Maybe they all do?
I assume the oscillation tells us it's getting voltage and hopefully the control board is good?
If the motor is toast, would it be a good practice to replace the control board along with the new motor?
1 - 14 of 14 Posts
