I will be installing a new electric dryer and plan on updating the 3-prong connection I currently have with a 4-prong connection. Consequently, I will be running new 10/3Romex for the 30 amp circuit. From the panel itself I plan on on using 10 guage THHN to run inside PVC 40 for a 36 inch run outside the panel up into the soffit. From there, I will install a junction box to transition from THHN to 10-3 Romex, then off to the new 4-prong dryer receptacle. Just wanted to make sure transitioning in this manner would meet code.
More impoprtantly, the dryer receptacle is located approx 40 feet from the outside panel box. On this long of a run should I use larger wire, such as 8/3 Romex instead of 10/3? Or will 10/3 be sufficient? And if using 8/3 instead, would I still use the typical dryer cord that comes with the washer?
Thanks for anyone's help.
