I am building a new bathroom on the second floor of my house. It is almost directly over the first floor bathroom. The house is slab on grade. The second bathroom is directly over a laundry room where the well pressure tank is located. There is a hole in the slab for the pipes from the well to enter the house and connect to the well tank. My plan is to bring the soil pipe from the second floor down through the laundry room and down and out of the house via the existing hole in the slab, at 18-24" below grade. It would then turn parallel to the house and run about 6', where it would intersect the existing soil pipe connector from the first floor bathroom to the septic tank/field. I prefer this plan to demolishing a perfectly good tile floor and concrete slab within the first floor bathroom, to try to connect to that toilet drain indoors. Are there any flaws in the theory of the external connection to the septic tank connector? I am in Connecticut, so I know I will need to be down below grade a code-required distance, as the existing connector "should" be (current depth unknown, but no freezing or backups have occurred in the 5 years we have had the house and it was a new system installed just before we bought it.) Any advice or feedback would be very much appreciated. I so don't want to have to touch anything inside the existing bathroom. :wink: Thanks!
