I'm currently in the process of adding a two piece bathroom in my basement. I had the waste pipe rough in done by a plumber and plan on finishing the rest myself.
The plumber left me about 8 inches if pipe for my sink. This pipe is in the wall right now. From there I plan to add a T where one side will come through the wall to my vanity, and the other will go up to a cheater valve. My first question is how high into the wall should the cheater valve be?
My second question is how high should the stub coming through the wall be at? Or is this mainly based on the dimension of my vanity?
I also plan on running water lines. For this, am I ok to run a line down the wall between both my toilet and vanity, then go from a T with one side going to the toilet and the other going to the vanity? or am I better coming down on the one side then going to the toilet then to vanity? or the other way?
Thanks!
Thanks!
