Just joined after looking for a solution to a wiring issue i was having on a project im helping a friend with..Wiring a NEW fan to an existing hot..Im going to try to run it to the garage door opener power above the garage..Im assuming< Hmmm :O) that its a dedicated line and can handle the ceiling fan 14/2 im running to it???:laughing:
Do you know what the fan requires, how many watts it draws?
I dont,Its a standard fan with no light kit..I think its standard,Im home now but when i get back there i can check it out? Ive done several fans in the past,But those were standard drill through the header to the switched outlet type installs,This is a vaulted ceiling and when i drilled through found ANOTHER cross member of 2by below about 5 ft down,so abandoned that...
