I have a unit that was installed at the end of the season of 07. ln the middle of 08 when it was not cooling properly I went to the airhandler and saw that there was ice on the pipe bringing in the refrigerant. I called the installer who sent someone to check the system. I needed approx 3lbs of refrigerant.
Now I am having a simmilar problem. I am not getting cool air and when I check outside where the pipes leave the condenser unit the pipe is not cool like it should be (or like the other machine is). Is it possible that one of the joints that they connected in the line was not done properly or got damaged? I did have a plumber desolder a pipe, with a little water inside (more heat to loosen the solder), right next to the refrigerant line for the ac. Can it be that he loosened/weakened the joint and caused a tiny (or not so tiny) leak? Is there a way to test a specific point for a leak? What would be the recommended course of action?
Thanks
Thanks
