When testing voltage at the receptacle with a load the neutral to ground is 0. Is this correct? Thanks!
Approximately 0, yes. Could rise to a few volts if there's a heavy load andSo neutral to ground should be 0 with and without a load then?
Yes it should. If it is not then you have a fault of an open neutral.So neutral to ground should be 0 with and without a load then?
