We recently moved into a home where many of the outlets are only of the 2 prong variety.
The service panel and service entrance has been upgraded to 200 amps and is all new work. Why they didn't address the rest of the electrical when they remodeled the kitchen and bathrooms and panel is beyond me.
Looking from the basement, it is clear that most if not all of the wiring does not come up from there to the outlets but must pass directly from the panel, thru the walls and then from outlet to outlet.
Many of these will not matter that a ground is not present as the type of devices used will not have a grounded type of plug used.
For the few that do and where possible would it be acceptable to drop down through the wall into the basement with a #2 solid wire, green in color and route back to the service panel and to the ground bus bar and then upgrade the outlet to a 3 wire type grounded outlet? I would do it this way because I cannot locate the path of the original feeder wire to get a new 12/3 all the way back picking up every outlet along the way.
Thanks in advance.
Thanks in advance.
