I'm a newbie landlord that has a multifamily home built in 1919 with three rental apartments. Each unit has its own Hydrotherm gas-fired boiler to provide heat to the radiators in that unit (each unit has its own h/w heater as well). Last owner put in all three boilers around the same time, 1986-1988, and now the largest capacity boiler, an HC -125 (125,000 BTUs), is starting to break down and require repeated repairs. Plumber told me three years ago that these boilers needed replacing, so I'm ready to look at replacement models.
I'm not married to Hydrotherm, so I'd like to know if anyone has any suggestions for brands that I should consider. I'm looking for a 120,000 BTU model that will only be used to heat a two-story (duplex) apartment under 2000 sq ft, and would prefer an efficient model that doesn't leave a huge carbon footprint.
Thanks for any guidance you can give me.
