Sorry to double post but I got no responses in the home theater section.
So I have a tv cubby hole that is located under a staircase. It was perfect for my DLP but I just bought a 64" plasma and it seems like a sin to stick it into the "hole". I was thinking of building a wall for the top 2/3 to hang up the plasma and leave the bottom open to stick a component rack. The hole is framed with wooden studs so I was going to frame the inside maybe an inch recessed with 2x4's(nailed to the 2x4's inside the wall) and then fill the top part of the cubby hole with a 3/4" thick board to the new frame.
Obviously I'm no engineer, anybody with the slightest experience have an opinion whether this would work? My main concern is that the wall will be "floating" and the 2x4's wont be screwed in together at the center. The fact that it's under a staircase, does that change the integrity of the studs? FYI, the plasma is about 75 lbs.
