I have a rear yard garden hose faucet / electronic pool filler assembly that is sweated to a 1/2" copper pipe coming out of a stucco wall. The problem is simple, the brass garden hose faucet has a slow leak, most likely a tired rubber washer after 30-years of service. The washer assembly wouldn't come out of the hole after unscrewing the stem / faucet handle cap. The next step also failed, unscrewing the entire faucet assembly and replacing it. The connection to a female brass T is 30-years frozen. I've let DW40 soak the joint and then tried to use a 12' heavy duty wrench after heating the T with a sweating torch. All to no avail. I'd like to avoid sweating off the entire assembly. The T connects to a plastic electric antisiphon valve and then schedule 40 PVC pipe to the pool. I'm concerned too much force well bend the short copper water supply stub coming out of the wall and/or break the PVC pipe.
All tips would be most appreciated.
