ok here we go...i have a carport that i boxed in so i could have another room in my home...i have the washer and dryer on the other side of one of the walls and i want to cut into that wall and tap into the hot and cold water as well as the drain so i can add a sink in my added room...ok, i understand and know how to do the water part with no problem but my question is what is the best way to tap into the drain and install the p trap for the new sink?...first off there is about a 16" drop between the two rooms so i will be below the washer drain, and that is why i am asking about this before i start the task...my thoughts are just to find out what size the drain is and cut it and add a tee then tap in like that but does this sound ok or is there another way i should do this?? please help!
