Hello all,
Been a long time since I visited DIYc. I hope everyone is well and safe.
After a lot of thought, I finally decided to redo the flooring in my 2 storey home.
The bedrooms on the second floor has parquet flooring, 2 bedroom has fairly new parquet floor (I am assuming based on the color)
The third bedroom flooring seemed pretty old and the floor creaked a lot, the flooring was also a few cms higher than the other rooms. So I decided to deal with this room first.
Took me almost 14 hours to rip off the parquet floor which were glued to a sheet of plywood. found each and every screw and removed the plywood too.
Drilled 2" screws into the sub-floor and the creaking has stopped.
Purchased Laminate flooring from Home depot today.
Now comes the part where I need your advice.
Some boxes had the plastic cover ripped so I ripped off the plastics from about 12 boxes, exposing the laminate floor. Only after I read the instructions on the paper under the plastic, I realised that the mfg recommends that boxes should be unopened. Will this cause any issues with the flooring?
The mfg also states that the floors should acclimate for 48 hours before installation. I was hoping to get the top floor done by Monday. will 24 hours be enough?
The mfg also states that once the boxes are opened, installation should be done immediately. I am confused here, wait 48 hours, 24 hours or start the installation
I've read that once the flooring is completed, give it 24 hours to cure. does that mean, I cannot move the furniture back into the room and start with the next room?
Please let me know of any other pro tip that might help me with this project
Stay safe and stay healthy
Cheers
Cheers
