The old house was built in 1909. The bathroom on second floor has two-side tub built into corner. Water feeds (hot and cold) mix and flow through 1 inch pipe that comes out of an American Standard fixture that also houses the overflow. It is a two-piece spigot/overflow collar fixture. Spigot is threaded onto 1 inch pipe; overflow collar fits against tub and spigot tightens up against it to complete the installation.
I have snaked into drain and gotten nowhere beyond 2-3 feet, not enough to clear drain. I have removed spigot from pipe to reveal overflow and snaked down through opening around pipe, only to have the snake head come into tub drain opening. I cannot get 1/4 inch snake to pass beyond the drain tie-in to overflow tube and get into clogged area of drain. I assume there is a T that is where my snake gets stuck, and a U or P trap below somewhere that I cannot get into/through.
Help with a diagram of this feed/drain/overflow configuration will help me figure out if and how I can snake this clogged drain without opening tile walls in bathroom and ceiling downstairs.
Thanks to all you "ancient" plumbers out there who may still have an idea what I am looking for.
