This float valve is in the tank for our Flood and drain (Ebb and Flow) greenhouse table system.
As the float rises it pushes in a small pieces of plastic. When the the plastic piece closes, it builds pressure in a small hose which then goes to what I believe is a pressure regulator with solenoid.
The float arm broke and I wanted to know the correct terminology for this type of float valve.
Bottom part in this photo
Float arm assembly (notice plastic break in pivot)
Float arm
The water is coming out of the port that would close when float valve is up
Float arm
