I have a Schluter shower stall area which is approximately 3 ft by 3 ft that I am planning on tiling along with the rest of the bathroom. One of the problems is that the Schluter Kerdi board was installed on a different plane van one of the walls that turns into it. So it basically stands about a half of an inch proud of the rest of the wall. The top half of the main bathroom is Sheetrock and the bottom half will be glass tile. I'm basically looking for ideas on a transition. There is 3/4 in trim on the upper half of the wall along with the baseboard that is running around the entire perimeter of the bathroom. I was thinking of putting up some type of trim that's 5/8 of an inch or greater in sickness the border the outside of the shower stall and have the trim and tile from the main bathroom run into that and then put a Schluter Edge on the other side inside the stall. I was going to use PVC since it will be so close to the shower. But I don't know if this is the best idea. Looking for suggestions. I've got photos attached.
