I was draining the sediment from my hot water heater. I have the slotted screw valve to turn on/off(Pic). To drain, I turned the screw counter clockwise valve on the valve to turn on the water. All was going good. When I turned the screw clockwise to shut off the water flow I assumed that that screw would turn tight to shut off the water. When I got to a certain point of turning the screw, the water shut off but as I continued to turn farther clockwise to tighten the screw, the water flow started once again. I turned the screw a bit counter clockwise to get the water flow to stop. Is this the way that the valve should work to shut off the water or should the valve be tight? Does the valve need to be replaced? If replacement is necessary, what are the steps needed for me to replace this?
Another question, I was going to check the anode rod on the same heater. From all that I have viewed, "typically" there is a bolt on the top of the heater that can be unscrewed to remove to check the rod. Of course on my heater it is different. I have attached pics of the top of my heater. Can I check the rod on it still? Is it the same but with just a bit more work to it? Thanks for all of the advice.
