1 - 10 of 10 Posts
It is a high shear mixer that will be used to emulsify a water viscosity coating
It may not work for several reasons. This is a 50Hz motor but the US has 60Hz power. This will cause the motor to run about 20% faster for the intended application which will create more drag and in turn torque. Coupled with the reduced voltage frequency ratio to overcome this torque the motor could overheat.
1 - 10 of 10 Posts
