So my finished basement has two different switches that control a set of lights, respectively left side and right side. The right side has 8
recessed lights that are all controlled by a dimmer switch at the bottom of the stairs.
There are another 4 lights on the left side controlled by a dimmer switch about 12 feet in to the basement near the laundry room. The picture will show 3 out of the 4.
I have just recently began adding a wall to create a room. That room contains 4 of the lights, 2 of which are the right side and the other two are controlled by the left side.
What I Would like to do is take control of these 4 lights and assign it to a new dimmer switch that I am installing inside the new room. How would I go about changing this configuration. I am prepared to remove drywall from the ceiling.
