Good morning everyone,
In my new home's yard I have this large tree (pine) that was surrounded by weeds and a large purple flowing plant. This area is higher than the lawn and was (until last night) enclosed with wood planks. They had rotted away and were falling apart. I want to put in a small retaining wall around the tree and select a more ground cover type of plant that works well in 1/2 sunlight (the house faces west and gets plenty of sunlight in the afternoon).
I removed 1/2 of the plants around the tree and found that the dirt was not just dirt but was actually a mixture of rock and broken up cement (don't ask me why). I'm looking for suggestions as to what I could or should do at this point.
I've included 2 pictures to give you a better idea of what I'm talking about.
My plan was to remove the rest of the plants/weeds, dig a small trench for the base of the retaining wall and level out the entire area. The problems I see concerns the roots of the tree and the existing dirt.
There are two roots that touch the surface where i would need to dig the trench for the wall. If i cut them in half will it be a death sentence for the tree? The roots are about 1.5 inches in diameter. Also, what should I do with the dirt? There are tons of plant/weed roots, rocks and cement pieces mixed in. Should i Just remove it and use fresh soil or should i attempt to filter out the rocks and cement?
Any help would be greatly appreciated. Thanks!
Sean
Sean
