Hi,
I have some rotted wood where the gutter is mounted to. I'm not sure how to proceed with the repairs and I was hoping that someone can assist with some recommendations with on to fix this issue.
From one of the images, the red arrow shows the rotted wood behind the gutter.
1. How do I remove the gutter from the wooded board? Is there is screw above the gutter that mounts it in place?
2. What is the best way to remove the rotted wood without causing any additional damages? Should I use a crowbar and carefully pry it off?
3. What size wood should the replacement be? Should I get pressure-treated wood and paint with a white exterior?
4. Should I cut a hole and install a downspout so water can go into the other gutter? Please refer to the GREEN arrow in the picture
