Thanks. Yes I wore a special jumpsuit i got at canadian tire and a dust mask that seals my nose and mouth. I also made sure to not disturb the insulation in case it was asbestos.
The house had an addition put in in the 70's, and all this insulation should be from then or later. Theres a few different types so some is visibly newer than others. The second to last picture is of some stuff that was under the original roof from 1955, so that has me worried. That hole leads to some wiring that I want to change out, so I will be manipulating it. My understanding is that asbestos was always loose like vermiculite, while the batts are most likely fiberglass.
