I am not Mr. Golden hands, but I need to replace a leaking radiator valve for my steam-based heating system.
I was able to remove the baseboard from the radiator valve (using Slant/Fin MultiPak 80), but I am having a problem removing the bottom of the radiator valve from the riser. I am using 2 large plumbing wrenches but I just can't get it to move so I can unscrew it. Attached below are two photos. On one of them, I have drawn up numbers so you or I can reference with comments.
What I have done is just put some WD-40 in between Nos. 2 & 3, as that's where I assume the thread is stuck. Or am I wrong?
I have been clamping the bottom wrench on No. 1 and trying to turn (counter-clock-wise) the brass-colored part of the valve by griping with the top wrench at Nos. 3 or 4. I assume No. 2 is part of the riser and should stay on it? Or am I mistaken?
Does anyone have any other suggestions besides me applying the WD-40 for overnight, to see if it somehow loosens this up?Thank you all for any and all input.
