The two old shutoff valves to my washing machine are completely frozen and I want to replace them with 1/4 turn valves. I want to make sure I understand what's currently there and what I need to do before I start. See attached pics.
1. I assume that what I'm calling the "elbow nut" is integral to the elbow, and doesn't turn independently from the elbow, and is just there to be able to put a wrench on it to prevent twisting of the pipe and joints when I remove the valve. Correct?
2. What I'm calling the "valve nut" appears to be integral to the valve, and doesn't turn independently from the valve, and is just there to be able to put a wrench on it to turn the valve. Correct?
3. I can see threads between the elbow nut and the valve nut on the cold water valve, but not the hot. Are the threads that are visible on the cold water valve part of the valve, and so do those threads screw out of the elbow nut? Or are they part of the elbow nut, and the valve screws onto those threads?
4. Given that my assumptions above are correct, I plan to put a wrench on the valve nut and turn counter-clockwise, while holding onto the elbow nut with another wrench. I may use some penetrating oil first to loosen it up.
5. I'd appreciate suggestions for a new valve that will thread onto the existing elbow on one end and be able to attach the washing machine hose at the other.
Thanks!
Thanks!
