I'm not sure this is the right forum (since what I have is bathroom wall tile and this forum says "flooring"); if not, please direct me to the right forum.
Please see picture below. The tile on our bathroom wall is probably original to our 1931 house. At least a few decades ago someone re-caulked one area, doing a sloppy job, with the wrong color, and it's cracking. I assume what they used is caulk -- it's "rubbery." The area they caulked is between the last row of flat tile at the bottom of the wall and the "curved" tile (which butts up against the floor tile).
I want to remove all the old caulk and re-caulk (or re-grout?) it. The gap to be done is 1/4 inch wide and also deep.
I started pulling the old caulk out with a butter knife, but there's many feet to do. What hand tool would make removing the old caulk easier -- A caulk removal tool? A "QEP" grout removal tool? Or ... ?
Then what is more appropriate to refill the gap: Caulk, or grout? I've read that caulk should be used at "plane" transitions, but I wasn't sure the curved tile was considered a plane transition. And what kind or caulk/grout? Any tips for what tools to use to apply it, and any that would help give it a nice finished look?
In case you can't tell I've never done any tile work before, so thanks very much for any help! / Rav
