I wouldn't do that. You just staple the wire in the groove and put back the molding.Once the wire is in the drywall groove, I'm assuming go right over with joint compound, primer, and paint?
If you want to install the speaker up on the wall ,you would get to the bay you want, cut a hole for the oulet box and snake the wires up from the floor.Oh my mistake... I didn't read close enough... you were referring to running along the bottom of the wall, I was wondering what happens once you reach the point in the wall you want to lift the speaker up vertically (if you are mounting on the wall I guess)? Sorry to hijack the post...
