I couldn’t find an aluminum screen door to fit my exterior door jamb so I had to get creative and now I can't seal the door for bugs.
I have stucco around my door that is not a flat surface or square and I don’t want to cut the stucco because it has metal studs behind it no am I not skilled enough to re-stucco. So I covered it with ¼” plywood and 2x4 door jamb.
The door works well, but now I can’t seal it for bugs. The exterior door threshold is too narrow to go under the screen door so I need a wide sweep to extend over the threshold preferably something to stickup, but screwed on if necessary.
I tried 1” self-stick foam weather-stripping around the sides and top and they fall off. I would like to use a Vinyl Foam Door Seal, but there are so many different styles and I can’t find one that works. I’ve bought a couple of different ones, but they look like they are replacements for something and I don’t seem to have all the pieces to attach them.
