I have any old *** furnace in my garage (it is solely the garage furnace). A few days ago the blower was making an awful sound. I removed the cover and belt and confirmed the motor/driver pulley is fine so it is a driven/blower issue (either the pulley bearing or the front shaft bearing or something inside). From my visual the shaft and bearing look OK and the noise seems to be inside. Though to confirm the pulley was OK I tried to remove it. The pulley has 1 bolt tightening to the shaft which I removed. However the pulley will only budge a few mm's - it will not come off. Issue is there is limited space for a puller and no room to hammer.
Any suggestions? Also if/once I get it off, would the bearuing generally be replacable or will I need a new pulley assembly.
Though it does sound more like it is something inside the blower, like a loose fan blade? Any suggestions how I can confirm where the issue is? Do fan blades fail commonly?
Below are a few quick pictures
