Hi All,
I'm hanging a projector screen in-ceiling and have already cut the hole. I've left the ceiling supports as-is until i can fortify them before making the cuts. Images here:
https://imgur.com/a/QXFFMlq
My question is, I'm planning on running 2 6x2x20" supports to support the central post (the one that has double 2x8's) as it appears to be a prime load bearing point (central to the ceiling), and the other 2x8 with a single 6x2x20" support which will be tied to the subflooring above, just as it is done at the edge of the ceiling.
I have a tight gap - at 6" to work with. My question is what hardware should i use to connect these 6x2x20" beams to the subflooring above?
I have observed that the supports in place from old work use the same support beams of 6x2x20" and to the subflooring panels above they just drove in 2 nails (what type of nails should i use for this?).
As i have no space to work here, i was thinking of getting a metal T bracket and flush mounting the bottom of the 6x2x20" support to the top of the subflooring runner as i can't possibly reach to the other side to drive in a nail or screw from that angle.
I would appreciate some expert advice here. Am i on the right track? or is there a better idea?
Thanks in advance!
Thanks in advance!
