I just finished tiling and grouting the bathroom with glass tile. I've got trim boards running around the room above the glass tile. I also have trim that the tile runs into as well as the baseboard.
Since the trim it is made out of wood, do you caulk or put grout in between the trim board and tile at the top? I'm worried about expansion and contraction cracking the grout.
I also need to drill a few holes in order to mount my mirror and towel holder. I do have a glass drill bit however I'm curious what would be the best anchoring method? I purchased toggle bolts as well as the standard drywall anchors. However between the thickness of the cement board which is half an inch plus the thinset and glass tile I was curious what would work better? My instinct was the toggle bolt since as you screw and it would draw in the clamps against the back side of the wall. But I don't want to screw anything up. Any suggestions?
