My house has a 1980's jetted tub installed in it (not big ...the size of a normal bathtub). It had a GFCI outlet installed on the circuit on another floor and the outlet was mostly concealed. I want to get rid of the GFCI there and put it closer to the tub where it's easier to see and easier to replace, when necessary.
The jetted tub has a wall timer switch installed across the room, and then there's a regular switch (like a light switch) installed in the wall next to the tub, under a cabinet, which controls power to the tub's motor.
I was thinking of replacing that switch with a GFCI outlet/switch combination (like this one). However, I've never used that switch to turn off the power to the tub (since we always leave that on and we use the timer to turn the jetted tub on and off) and I don't need an outlet there, so was wondering if there's any disadvantages to just replacing the switch with a blank GFCI receptacle? Or I could even just remove the switch and put in a regular GFCI outlet (to save money), even though I don't need outlets under the cabinet.
Is there a reason that a jetted tub needs to have an on and off switch separate from the timer switch? Code, maybe? If I had to work on the tub's motor, I'd turn off the whole circuit anyway, so it seems unnecessary to me to have this switch.
