The inside of this custom wine cabinet (my first) will have frameless bypass sliding glass doors. I designed it based on a cabinet that the wife and I saw at a local bar.
1. Can I just stain the edge of my center divider since it will be behind the glass or can I get some kind of stick on veneer that is stainable? OR can I use a half round piece of wood trim? Plywood is 1/2" and I found a half round at home depot that is just over a half inch.
2. I already installed the back, sides, top and bottom. I know I shouldn't have but it's in there now. I used a pneumatic nail gun so it would be tough to undo. For attaching the center divider, I am thinking of adding a second top piece and cutting a dado slot to better secure the center. Is that necessary OR will it be secure enough if I do a couple of pocket holes to secure the center to the top?
3. What's the cleanest way to attach the wine holders on the left side given that the inside sides are already in?
4. On the right side, I plan to make those steps have hinged tops so I can hide an electric outlet and LED light control module/wiring inside. Any suggestion on how to do the lids? What kind of hinges?
Thanks
Thanks
