My house was built in 1949. Originally the only venting was a mushroom other either side of the roof for each knee wall. The soffits are hard-pan and enclosed (under the hard-pan soffiting theres just solid board)
I had a crew come and install a ridge vent this week and I was hoping to simply hole saw a vent into the board above the soffit pan for each bay, cap the holes and install some soffit perf.
Well, now I'm not sure what to do. Each of the birds-mouths are stuffed with some old school loose fill that I moved aside to get a better look at what I'm dealing with. Instead of seeing the top of that board above the hard pan, I'm seeing this:
To help describe... I've pulled the batt back aware the vertical board that is in front of it. the best I can tell, underneath the bat to that board is the drywall ceiling downstairs (I think). Beyond that board (where you can see some tar paper) is another that seems to sit at a 45* angle.
So my question is, how in the heck is this thing built and how do I to vent my soffits? Will I have to hole saw through the board above the hard pan and then hole saw into this angled board as well?
I was going to use a 2" hole saw for each of the 25 or 26 beam pockets. Should this be enough? If it helps, they installed Owens Corning Ventsure [link] [12.5 sq. in. per lineal ft] I would like to make sure that if I'm going through the pains of this to make enough intake, e.g bigger hole, more holes per bay, etc
Heres a snapshot taken from further back so you can see the construction of the eves better:
(the close up picture of the bay is to the left of the one shown center here)
outside view of the soffit:
Any help, diagrams, pictures, etc would be greatly appreciated.
thank you and have a great holiday weekend
