1 - 2 of 2 Posts
I have a 10' X 22' metal roof that has styrofoam incased inside of the metal (have no idea what this product is called).
This is on a outdoor aluminium lanai that I use as a living space. the roof is like said aluminium with styrofoam inside as insulation. they are 10' by 4' panels that i suppose groove together but are leaking in some of the seams.
There was butyl tape and silicone put down the seams but i dont think they had uv protection and have given in to the weather.
My questions are these (opionions appreciated)
1) should I take off old buytl tape and clean before fixing with new product?
2) should I just fix with a uv approved butyl tape like eternabond? is this good stuff (I live in florida and is exposed to max sunlight)
3) Should I think about covering the whole roof with a uv rated type of peel and stick or should I use a torch down material.
I would like some kind of insulating roof product if I should do the whole roof what is the best product for my style of roof?
4) I know that I could remove the old butyl tape and clean and use a white roll on roof kind of thing but doesn't this stuff start peeling up after awhile and cause a big mess?
Silicon sucks because silicon only sticks to silicon. Are you sure it's silicon or are you using that as a generic term for caulk?
Contact a roofing contractor to install a flute fill single ply roofing system.
1 - 2 of 2 Posts
