I am remodeling a bathroom that has a showerhead, pressure balance valve, and tub spout with diverter. I would like to replace this setup with a new showerhead, pressure balance valve with bath/shower diverter, and tub spout. My question is what plumbing rough-in modifications are required (if any) to relocate the diverter from the tub spout to the pressure balance valve? I have included sample before and after pictures to depict the existing and desired location of the diverter.
For example, do I need to install a pressure balance rough-in valve with built-in mechanical diverter? And if so, is there an existing tub rough-in valve with mechanical diverter that needs to be removed and replace with something different?
Retired Moderator
Post a link to the installation instructions for that unit.
If you move the diverter from the tub spout to the valve, you need a valve with a built in diverter and a spout without the diverter. Nothing out of the ordinary.
Retired Moderator
I looked up that brand---standard installation---
However, where will you be able to find parts for that ?
Shower mixers need servicing in 5 to 10 years---can you find parts locally now? In 5 to 10 years?
Not wise to use a nonrepairable unit----check with your plumbing supply house about parts----
