Ok, I need some help/advice.
I'm up in my attic trying to airseal some areas and I came across this.
This is where my outside brick wall/porch meets the inside bedroom wall.
There is a gap between the attic floorboards, but this gap is only across 2 joists. There is a board cover the gap over the other joists. Does this need to be sealed? If so, what's the right way.
Should there be this kinda gap between the brick wall and interior wall construction??
As a new homeowner I am not sure if this is constructed correctly.
I assume the floorboards need to be sealed, to stop airflow from getting into the bedroom.
I think the air is starting in the attic, going in the crack traveling all the way down my wall and coming into the bedroom from the bottom part/rug.
Please see the album for pictures as I realize this is hard to explain.
http://www.diychatroom.com/members/alumifab-58934/albums/attic/
