I have a vinyl tiles that I put down on my kitchen floor four years ago. After about six months, I noticed that most of the seams were opening up. So I just let it go, until now. I believe the plywood underneath was not prepared properly. It was clean and smooth before I put tiles down.
I also believe I did not help matters by using water with cleaner and a deck brush to scrub the new tiles as I think water gets below the tiles and makes the plywood swell up, causing the seams to open up. Do you agree that this is a possible cause? What are the remedies?
If I have to start over and remove the plywood flooring (1/4 inch I think) then The only problem I see is that kick plate area on the base cabinets would be a difficult area to work on with any tool to cut the 1/4 inch pylwood right up to the base. So I need advice for this area too.
I think this flooring contains a lot of moisture and I would not mind ripping as much out as I can.
I believe that I should also seal the new plywood with the best sealer, rather then taking a chance and sand down and clean the old plywood.
I don't know if hardwood flooring is under the plywood but I do have 3/4 tongue & groove subfloor. So How to proceed and what materials from nails, adhesive and replacement flooring would you use?
