The speakers should come with a template. You just need to get the hole big enough for the speaker to fit into, and then the grill will cover it. If you are good with a drywall saw, or even a rotozip, it can be done.
They don't score the paper on the backside (topside), which can result in problems when you punch it out. Though, you can use it to mark your circle, before finishing the cut with your drywall saw.you also can get one of these
Could you elaborate please? What is the problem? There are no clearance issues, I've checked it.You are seeing it the same that I am. Total pooch screw on this, with poor planning of the location of speakers & lighting.
