Hello All,
first, let me state that I am NOT an electrician by any stretch of imagaination but I do have basic understanding of what is needed. Here is my current problem.
I am moving into an older home that currently has 100 amp service. The main panel is located in a back bedroom and the meter is mounted to the house on the outside wall in the same location. The service panel is small and is completely filled. Not the issue since I know I need 220 for the hot tub and this panel cannot provide it. Unfortunately the final resting place for the hot tub is on the OPPOSITE side of the house so I need to figure a way to get service from this panel to the hot tub location. There is no crawl space nor is there attic space to run wiring. So here are some questions.
1) will the power company have to make any changes to the existing drop?
2) can I install a sub-panel to gain the additional amps needed and not have to replace the existing 100 amp panel?
3) what method would you recommend to get a line from the existing panel around the house to the hot tub location?
4) if I am facing the cost of replacing the existing 100 amp panel with a 200 amp panel, would it be less expensive to just have the power company just drop me a completely separate service (with a meter) to the hot tub location?
It is being suggested to me that I am probably looking at anywhere from $800 to $1000 to just upgrade the existing 100 amp panel to 200 am service and then probably another $1000 or more to get the hot tub wired up from the upgraded service. I need to find a less expensive method if one is possible.
Really appreciate any advice here. Many thanks!
