1 - 16 of 16 Posts
I bought a year old Lawn Boy push mower (Model # 10730) at the end of last summer. The seller said he had used it only 4 times, and it definitely looked like it had barely been used.
I used it once at the end of last season, and had no issues with it. I used ethanol free fuel (Tru Fuel 4-cycle) since it was the end of the season, and then I let it run out of fuel.
I tried to start it up for the first mow of this year this afternoon. I had no luck just pulling on the cord (this model does not have a primer bulb), so I took off the air filter and sprayed some ether into the carburetor and then pulled the starter cord. This caused the engine to rev for maybe 2 seconds, and then die.
I tried this again and got the same result. Then I did this again and continued spraying short bursts of ether into the carburetor. Doing this, I could get it to keep running, but as soon as I stopped spraying, the motor died.
I would have assumed the issue was bad fuel, but I ran the motor completely dry last season, and the last tank of fuel was the no ethanol stuff.
I'm not very good with engines. Any idea what could be the issue? I'm pretty bummed that my new (to me) mower is already giving me trouble!
Thanks for any and all advice,
Andrew
Tap on the carburetor with a hammer and try again.
Reactions: newguy101
Lawn Boy has not been made for many, many years.
I'd just try ordering a new carb. on EBAY and give it a try.
That would get old real quick for me having to use mixed gas in a mower.
I got tired of dealing with used poop long ago and trying to save a buck.
My new Toro is guranteed to start and does every time with no more then two pulls.
I am confused by this post. The lawnmower is only a year old. Here is the exact mower for sale at Home Depot:
https://www.homedepot.com/p/Lawn-Bo...Push-Mower-with-Kohler-Engine-17730/204635383
What do you mean by "having to use mixed gas in a mower"? I am not using mixed gas.
Either I am very confused, or you are confused. It's probably me, but I'd like to get it cleared up.
Taping on it would have been never suggested by 99% of the people that work on small engines for a living.
Yes you would have to take the whole thing apart to clean it but even then most DIY's do not have the proper tools to do it.
Far easier to just to replace it.
Just to really clean it right the whole thing needs to come off anyway, as old as that is the gaskets will also need to be replaced.
A whole new carb, with new gaskets, air filter, spark plug, fuel lines on EBAY may cost about $20.00.
Just my personal opinion I would not waste even the $20.00 on a Yard Boy mower.
Discussion Starter · #10 ·
I am confused. Why do you think it is old?
· Usually Confused
I dunno - the one I have built in 1980 or 81 still runs fine. Maybe newer ones are different.
Description in your HD link says:
3-year tru-start commitment starts on 1 or 2 pulls or Lawn-Boy will fix it for free, ask your retailer for details
2-year no worry warranty starting, power, parts it's all covered under Lawn-Boy 2-year complete coverage warranty, ask your retailer for details
Might want to take it to a lawn boy authorized repair shop if it is that new
Discussion Starter · #16 ·
So I ended up taking the carb apart today. There was some "jelly" in the bowl. Other than the jelly, everything looked really clean. I cleaned out the bowl, and now it runs great.
My theory now is that the guy must have let gas sit in it for a yr before I bought it. The weird thing is that when I bought it from him, I was able to mow successfully with it once before last season ended. And I made sure to mow with ethanol free gas (I first emptied the tank of the gas that was in it).
Anyways, all is well that ends well. Thanks for the input.
1 - 16 of 16 Posts
