· OregonThe Shower me state
If this isn't the right forum I think but given all of the work done in this section I thought it may be appropriate. I have a pair 85-323A's seem to continue charging without going to standby mode as they did when they were new.
I ran a voltage test on the newest and it was charging at 5.28V, the older one at 2.59V I was thinking there's burned out diodes in these guys that I may be able to repair, and get the parts from Mouser.com or somewhere.
I was digging on some YouTube vid recently and it seems the large footprint chargers can be rebuilt by means of checking out the rectifier or the thermal switch. Since these two have low voltage rather than none at all I may be looking at a portion of the diodes being burnt out if I'm barking up the right tree. The internal components look familiar with that large format charger I saw on YouTube. Given as this is the small homeowner size it looks like the 85-323A has a sealed rectifier;
I learned how and checked out the bridge rectifier yesterday with my multi meter and the diodes seem okay. So a Voltage Regulator circuit on the board that may be the cause, the internals of these old chargers is rather simple and I'm hoping to get to the bottom of this. On the other hand as NAPA no longer carries this type of battery charger anymore that may be an indication that they're just build shoddily and superseded.
I was able to find the Battery Tender Plus (1.25 Amp) charger
that I used to use on my turbo Z bike, it still works so I'll use it to keep my secondary battery on my Jeep up to snuff in the meantime.
Here's what the innards look like on these chargers, and I found no sign of overheating anywhere;
...and here's a close up of the circuit board;
I'm told from another forum that the issue may be with the Zener Diodes
on the board, does this sound right?
Thanks and a lift of the lynch lid for any help and advise.
Gus
Hi Gus, hard to troubleshoot without a schematic and hard to get a schematic for just one repair. A common failure I ran into was associated with components that produce heat, the heating and cooling gradually fractures the solder connection.
Two ways to check, a real close visual for a crack line around the wire or related lead. Sometimes hard to see.
The other way is to place the tip of your finger on the lead passing through the board and try to move the component. When this works your eyes will light up (no power) with an awe moment. After having repaired thousands of similar machines it became easy to spot and test. Re-solder and problem may be solved.
Read an article many years ago that circuit boards returned to big blue were not worth trouble shooting, but something like 75% were restored to working by running them through the wave solder machine, basically just re-soldering everything. When that didn't work they dumped all of the components, salvaged the empty board and ran it through the assembly line to make a new one. I never understood that but some penny pincher must have worked the numbers.
Bud
