1 - 20 of 24 Posts
Hello
My wife noticed an issue on her rear driver tire.....pressure was very low (sensor showing 14psi)
She took her car to the closest tire repair center which was a Walmart
They said it was a nail, but not repairable because on the sidewall....So I thought it was a nail into the flange
When I came back home, I took a look and saw the nail....is this really not repairable (nail is visible on the right side of the tire)?
Although I have almost never been in a Walmart, twice I think, I have heard a number of people speak favorably of them, particularly in regard to tires. And sidewalls can be unforgiving on radials, but that doesn't look like a side wall to me. So I understand pricing, as well as loyalty, but unless I was ready to buy a new pair or set anyway I would stop by a Discount, Belle, or whatever you have and get a second opinion. Not that tires are anything I would gamble with, so I wouldn't be looking for the guy doing it in a back alley, but would want to see what a second legitimate party had to say before biting the bullet on a new one.
· Master General ReEngineer
Hello
Ayuh,..... Go to a real Tire Shop,.....
That nail is clearly within the tread,......
Over the corner is the sidewall,......
Have 'em break the tire down, 'n do a patch repair on it, then remount, 'n balance if necessary,....
Yank it out and put a plug in it.
Reactions: Mystriss
I have also heard that nail in the sidewall should not be repaired. It's just that, to me, a non expert, that nail does not look to be in the sidewall.
I would say its worth the trouble to get a second opinion.
A pan head sheet metal screw works as a excellent plug until you get your SS check next month. She stays right there at 70 on the pike. If a guy forgets and the head wears off the tire shop has no problem getting it out when they remove the tire to fix it the traditional way.
https://www.amazon.com/dp/B000ET525K/ref=twister_B07KPGGVPN?_encoding=UTF8&psc=1
Isn't the best kit, you can find a decent "pro" kit for $20, but that's all they typically use to fix the tire in a shop. Only thing you lose is the warranty or whatever on the patch work if it fails. Husband patches nails and screws all the time due to 100 mile a day commute through housing construction zones and we've never had a single patch fail in 20-some years.
Your pic shows the entry point of the nail and if it went straight I agree it should be repairable.
Did you verify that the tip did not exit in the real sidewall?
Ayuh,..... On My pickup, that's exactly what happens,......
I carry one of the "Pro" kits Mystriss mentions, in my truck,....
The pull-through patches pictured above are probably the Best,.....
Atleast they attempt to seal the water go of the steel belts,....
My kit uses the brown corded Camel push-in plugs,.....
totally repairable, by somone competent, had one in my BMW last week
and that's NOT in the side wall
Hello
1 - 20 of 24 Posts
