1 - 7 of 7 Posts
What type siding do you have?
In most cases what's what holds it in place, keeps air and water out, once you apply the sealing tape over it.
· journeyman carpenter
· Banned
Yes.
If you are doing it via pocket/insert replacement and not pulling off the siding, brick, etc, you can put it in as pocket style door.
Pay special attention to the flashing and moisture management detailing as mentioned above.
Can you post up a picture?
· Registered User
I agree, if you absolutely need too... score both sides of the flange with a utility knife and bend it back-and-forth a few times.
As posted already------------------ before you cut it off----------- a picture of the application would help.
http://www.diychatroom.com/f98/how-attach-photo-post-20532/
Gary
· Home Performance
+1 to WoW's post. In fact, many doors don't even come with a flange. Be aware however, that this can make the flashing (aka: weatherproofing) of the unit a little bit more complicated and less DIY friendly, as custom bent metal is usually required.
1 - 7 of 7 Posts
