1 - 6 of 6 Posts
We had an Ash Granite walkway installed a few weeks ago. There are 2 issues I wanted to show you.
1 -
Right after installation, we noticed this weird, unnatural-looking lines in the granite. They aren't recessed really. Maybe a tiny bit but basically flat/flush. Pretty uniform across most of the tiles.
The contractor said he's never seen this before and the stone supplier isn't sure either.
They both said it may weather way in a few more weeks. I'm not so sure about that.
Anyone know what this is and if there's a fix for it?
2 -
And secondly... the contractor didn't buy enough tiles for the job, so he had to go back to the stone supplier and get 2 more tiles, which are much darker. I complained and he went back to try to find a closer match and couldn't find the same as the original color. He says they will even out over time. Is this true? It's been a few weeks and it's getting slightly better but not a big difference yet.
Also, there are scratches on those 2 tiles. Is there a way to remove them?
Thank you!
1. It's not that noticeable, but maybe a little buffing could help.
2. This is a bigger issue, as the 2 tiles are completely different colors.
Accepting this is up to you.
When I do a tile job, I get as many as 10% more tiles than I need, from the same pallet, same stock, same color. Every tile job has: damaged tiles, cuts, broken tiles and extra tiles for future use.
If a tile setter, who buys the tiles, ends up short of tiles, he is not a pro, can't figure how many tiles he needs or can't count, multiply and divide.
If you provided the tiles, then it's your fault.
I'm thinking the lines were caused by the equipment that surfaced the stones. I could probably live with that, its so close to a natural vein.
The 2 darker stones will never match the others. Tell the installer to replace half the light stones with dark, and do a checkerboard pattern. Or replace all of them so they match. Not your problembwe didnt order enough. Typically you order 10% extra.
Thanks for the response. Is it a big job to replace the stones? They poured concrete as a base, so I'm guessing they're really stuck in there. Which of course is good for the long haul but not so good if we want to replace.
Depends how they were installed. The concrete could be a solid base and the stones are set on a sand bed. Might be set with thinset which be tricky to remove.
1 - 6 of 6 Posts
